Point Processor Light.exe
Message 1 of 9
Hi we recently just got a new antivirus. It is wanting to flag Point Processor Light.exe. I am trying to see if this is part of CAD or revit so that we can white list it or keep it blocked
its found under
"C:\Users\USER\AppData\Local\Apps\2.0\RPX1CLLR.9W1\E24W1R7V.3TA\poin..tion_7a48d120b4e0fcd1_0001.0003_acaa89f7472b3e5b\Point Processor Light.exe"
Replies (8)
Message 2 of 9
Alfred.NESWADBA
I have installed a lot of different AutoCAD releases and verticals, I also have installed Revit 2020 (but not with every add-on), however, searching for "*light.exe" does not show any file existing with that pattern on my system.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
Thanks for the reply. I think this is an addon. I am the network guy and dont install this at all. And the tech support guys were unsure
Message 4 of 9
Alfred.NESWADBA
Right-click this exe and look into the file properties. You should see the vendor and so get from them the info about needs to exclude that from AV-scanning.
- alfred -
Alfred NESWADBA
Message 5 of 9
I found a help.pdf the first line is "Steos to create Coordinate points using the "POINT" Command in AutoCAD or AutoCAD LT
Message 6 of 9
Alfred.NESWADBA
>> I found a help.pdf
From which software vendor, I doubt that this is from Autodesk.
- alfred -
Alfred NESWADBA
Message 7 of 9
Message 8 of 9
Alfred.NESWADBA
may I ask what this link (showing how to create points in AutoCAD) has to do with lights or with your exe-file?
Sorry, is not clear to me...
- alfred -
Alfred NESWADBA
Message 9 of 9
pendean
Community Legend
Community Legend
HELP file? Why not look at the actual file in question and discover what it is instead?
Here is how you do that: Find the Point Processor Light.exe file listed in the path you listed, right-click on it, select PROPERTIES then click on the DETAILS tab and find out more about the program and Author. Let us know.
