POINT LABELS
POINT LABELS
MarkvonT
Observer Observer
POINT LABELS
MarkvonT
Observer
Observer
Once I have uploaded a set of grading points from an excel sheet to AutoCAD, I'd like to know how to label each reference (point) with Z(height). To clarify I have each point on excel with X..Y..Z...I then upload the coordinates to AutoCAD but I would like to know how to automatically label each point with their specific heights.
pendean
Community Legend
Community Legend
You need to be using MAP3D or Civil3D variants for that more intuitive ability: the former is free to anyone with an active subscription, the latter requires a new subscription https://www.youtube.com/watch?v=2Nh9UtOPYkg
LyleHardin
A plain AutoCAD solution would be to make the point a block with an attribute that would report the Z value.
Then, you can use your Excel sheet to create a script file that inserts the points at the proper coordinates, and enter the attribute value with the z value.
Without testing, your script file made from the Excel sheet would look something like this:
-Insert pointxyz x,y,z 1 0 z   (give or take)
where pointxyz is the block name. x, y, z are the coordinate values of your point. The 1 and 0 are scale and rotation. That last Z value would be filling in the attribute value of the block.  Note that I'm probably missing something because I'm just doing this from memory.
LyleHardin
Another option if they already exist in the drawing as points and you don't want to re-insert them is a relatively simple lisp routine to find all the points and enter text next to them that reports the Z value of their coordinate.
I've looked in my arsenal, but I don't have any that do specifically that.
You could also use your same Excel file to create a script file to just enter Text at that coordinate.
-TEXT x,y,z 0.1 0 Z
Where -TEXT is the command, x,y,z is the coordinate, 0.1 is the size, 0 is the rotation, Z is the elevation value for the text.
