PNG plot showing in isometric view instead of top view
Message 1 of 14
  I've printed a model top view to PNG format before, inly this time it's not comming out properly. My view is from TOP, and in the preview of the PNG plot shows an image from the TOP, but once I click "print" and view the image, it shows in isometric view. Any suggestions are welcomed. Here's an image of what I'm getting:
AE
Replies (13)
Message 2 of 14
Alfred.NESWADBA
it looks like pixel-shifting, does the same happen if you create a new PC3 file for PNG or if you try the JPG-format?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 14
Hi Alfred,
  It's not a new pc3, it's the one that's already listed in the options. When I print as a JPE file, it happens the same. But when I print as PDF, the drawing looks normal, from a top view.
  Thank your for your reply.
AE
Message 4 of 14
john.vellek
Hi @Anonymous,
If you are using the default PublishtoWeb PNG I am curious if this happens in all drawings or just this one. If it happens everywhere, open the PC3 file and click on defaults. Then try another plot.
If this still is not successful, you might consider logging on as a different user to see if the same behavior continues.
John Vellek
Message 5 of 14
Hi John,
  Apparently, it's happening with only some of the pre-configured sizes I'm selecting, but only with this drawing I presume. The User 1 (1723 x 1115 pixels), and the User 1 (1115 x 1723 pixels), so far, are resulting in the isometric view. But the 5100 x 3300 pixels one is printing correctly. What's even more weird, is that the first two, which are the ones giving me the isometric view, in the preview are showing the top view. I still can't figure out why with these sizes of plot gives me the isometric view on this specific drawing.
  Thank you for the advice.
AE
Message 6 of 14
john.vellek
Hi @Anonymous,
Is it possible to attach a sample drawing? I would like to first see if I can duplicate this behavior on my computer. Then, I would like to try to rebuild those sizes in the PC3 to see if that remedies the issue.
John Vellek
Message 7 of 14
Alfred.NESWADBA
just a silly idea, does that happen with sizes which have odd (instead of even) pixel numbers/sizes?
- alfred -
Alfred NESWADBA
Message 8 of 14
¡Yes!
Hi Alfred, indeed that's what is happening. When I pick a size which has even numbers in both sides, the image plots correctly. And if I pick a size that has odd numbers on either one or both sides, the image plots with the isometric view. That's the root of the issue! Thank you! Now it only remains to find why.
Thank you for commenting.
AE
Message 9 of 14
Alfred.NESWADBA
Great! Can you live with that?
I'll guess that is Autodesk's job 😉
- alfred -
Alfred NESWADBA
Message 10 of 14
I can, but I'm also curious to know the precise issue to solve the problem. I'll give you the kudos though.
Thank you!
AE
Message 11 of 14
john.vellek
Hi @Anonymous,
I would like to see if I can reproduce this on my side so that I can log it with Development.  Can you tell me which Operating System you use and the exact version of AutoCAD?
Also, does this happen in all files or just one? Can you attach a sample file for me?
John Vellek
Message 12 of 14
Hi John, sure thing...
I'm using Windows 7, 64-bits, AutoCAD 2016.
As far as it goes, the issue is occurring only in one file, but I cant share it since it's from a client, but I'm attatching the file without content. Hope somehow it still shows the issue.
Thank you for your assistance.
AE
Message 13 of 14
john.vellek
Hi @Anonymous,
This is very curious.
I was able to take your file in AutoCAD 2015 and duplicate this anomaly. I created a 2nd drawing and could again recreate the issue.
Then I tried in 2016 and 2017 but could not duplicate the action.
You have me perplexed 🙂
John Vellek
Message 14 of 14
That means it's probably an error from that AutoCAD version, and not from some specifications in particular.
Thank you for your reply!
AE
