PNG added as OLE but doesn't appear on published pdf.
angel.delgado2N7KQ
Observer Observer
angel.delgado2N7KQ
Observer
Observer
Using AutoCAD 2023. There's no viewport. I INSERTOBJ a PNG. Publish to pdf, but when I open the pdf, the object isn't there; meanwhile the other content shows up.  I created these PNGs from Acrobat and I've tried numerous resolutions, as well as publishing with various resolutions and still nothing. I've also tried bring to front. I also get a warning stating, "Failed to rasterize image for plot."
I can't attach the objects because the file needs to stay a single file without local dependencies. Also, I'm not allowed to share the file.
paullimapa
If the problem occurs with all png files then attach a zip of a sample dwg that contains that png file that you can share.
But if the problem only occurs with a specific png file, then most likely the cause is the png file and not AutoCAD.
Paul Li
IT Specialist
@The Office
jayhar
Could you please share the PDF file? Before that, kindly try running the command GRAPHICSCONFIG and turn OFF the settings.
If you re-insert using IMAGEATTACH and save the PNG as a standard non-transparent image, the error will go away
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
cadffm
Publish/Plot OLEs needs full print support, make sure you are jsing plot/publish in foreground.
BackGroundPlot = 0
Sebastian
