>> Is there a autocad api is availble
If you have read the discussion about you know that the PLT-file is not an Autodesk file format.
- If a PLT-file was created for HP-plotter the file may be of type HPGL, HPGL/2, HP-RTL, Postscript ... you may find converters for these formats.
- If a PLT-file was created for a Brother printer, you have to ask Brother to get the definition how they write their files
- If a PLT-file was created for Epson, you have to ask Epson about their format of plot-/print files.
None of them is a file that Autodesk writes directly as AutoCAD sends the geometry content to the driver and tells the driver to send the content not to the device, but redirect it to a file. Without knowing for which printer (and which language, if the printer can receive more than one) you can't say "convert an unknown file format to a PDF" ... and you can't find an AutoCAD API that can convert unknown file content, written for Brother, Epson or other devices.
Hope it's better to understand now.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
