Plotting to PDF Qaulity
mike_g
mike_g
When I plot to PDF I use the 'AutoCAD PDF (web and mobile).pc3', which I think is a default setting?
Anyways, the PDF ends up being very data heavy. Hatching wants to reload every time you move the page or scroll down. Book marks are created, and the sheets are typically 3-4 mb a piece.
I used to be able to plot to pdf and none of the pdf data came in with it. The picture did not want to reload every time you scrolled, each sheet was around 1mb a piece, etc. A setting must have changed on the last update though.
Is this a setting I can change to make this stop happening? Hopefully that makes sense...
0 Me gusta
Responder
248 Vistas
1 Respuesta
Respuesta (1)
imadHabash
if you try to plot it from another machine ( if available ) , does the same happend ?  also we're glad to try it for you if you upload your CAD drawing here ?
Imad Habash
0 Me gusta
