Plotting to EPS
Plotting to EPS
No aplicable
Hi, I was wondering if someone could help me sort out this problem. I installed and re-installed (following typically recommended steps : Add a plotter>my computer>postscript>plot to file ) the postscript plotters. When I go into my print command, and select any of the postscript plotters, I can preview them. They save with a .eps extension. However, when I try placing them in Illustrator CS5.1 or Photoshop, they are blank. What am I doing wrong here ?
0 Me gusta
Responder
Soluciones aceptadas (1)
797 Vistas
3 Respuestas
Respuestas (3)
imadHabash
Solución aceptada
Turn off plot transparency..
Good Luck..
Imad Habash
No aplicable
That worked !! Thank you so much !! So, what happens if I want to plot hatches with reduced opacity ?
0 Me gusta
imadHabash
I think this is a real problem that fellows in Autodesk must worry about.
Imad Habash
0 Me gusta
