Solved by john.vellek. Go to Solution.
>> ..to plot a drawing in AutoCAD which is very big in terms of metres.<<
you have to know that plotting procedure depends on Paper size and scale information.since we know that AutoCAD can make custom paper size reach to long 5M .so you have to select proper paper size then the scale will be recognize.
Hi @sudhakarseven,
If the posts in this thread don't help you get started, please attach a sample file and tell me the scale at which you want to plot. I will happily provide you some set-by-step assistance.
Hi @sudhakarseven,
I didn't have a plant drawing in metric so for my example, I took a floor plan of a building in metric. I created a video to help you with the steps.
I see first that my model is all drawn at real size (1:1 scale)
I then switch to a paperspace Layout tab.
On this tab, I use Page setup to define my plot device (AutoCAD PDF), Plot Style (acad.ctb), scale (1:1), and paper size (A3)
I apply this new page setup to my layout.
Now I create a viewport to see my model by using the MVIEW command.
I double-click to enter this viewport and set my scale from the scalelist at the bottom of my screen.
While in my viewport, I also pan to the area i want to plot.
I switch back to paperspace and use Plot to achieve my final PDF print. This could also have been done using a different printer driver to print straight to a piece of hardware.
I hope this gets you started.
HI @sudhakarseven,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Hi @sudhakarseven,
Setting up Annotative text and styles is fairly simple.
For instance, when I know that I want my text style to be annotative, I create a unique text style and set it to be annotative. I then can determine the height of this text for paperspace.
When I start creating my first text object with this style will be prompted to set the Annotation Scale
Next, when I go to paperspace I set my viewport scale to 1:1 and my text is displayed at the height I set previously.
If I want to add additional scales I can select the text, rt-click for Properties and then add Annotative scales.
Once I add the scales, I can zoom in my viewport to those scales and the text will show up properly.
