PLOTTING ON CAD IS CREATING A PLOT TEXT DOCUMENT
Hello, I been running into an issue every time I publish on AutoCAD it creates a text document called plot. I was hoping someone knew how to fix this issue. Thank you.
nrz13
1) Enter OPTIONS at the command line.
2) Select the "Plot and Publish" tab at the top.
3) Click the "Plot Stamp Settings..." button in the lower-right-hand corner.
4) Click the advanced button in the lower-left-hand corner of the dialog that pops up.
5) Uncheck "Create a log file".
6) Click "OK", then "OK", then "OK".
Steps 1-3Steps 1-3
Step 4Step 4Step 5Step 5
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
