plotting multiple files (DWG to PDF.pc3)
Manicbala
Manicbala
Dear all,
While i'm plotting multiple files (DWG to PDF.pc3).It's always saving single file.
I need separate file for every file. I tried both Single-sheet file & multi sheet file.
I'm using AutoCAD 2010 version.
Anyone help.
Bala
Alfred.NESWADBA
do you mean PLOT or PUBLISH?
Because the command PLOT can only plot one layout to one file, so no way to get multiple layouts/files into one PDF.
The sysvar that might help you is PUBLISHCOLLATE (>>>details<<<) ... if your's is set to 1 then try it with 0.
If you run PUBLISH you can also look to "Publish Options" within the PUBLISH dialog and see how the PDF-option "Type" is set.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Manicbala
Thanks alfred.
That's for Publish. I changed PUBLISHCOLLATE to 0. Its working fine now.
Thanks again.
Bala
