PLOTTING LOT BEARINGS
j_gonzaga_528498
Message 1 of 11
j_gonzaga_528498
Hello!
Can anyone help me with plotting the lot bearings? I don't have an actual lot bearing from a surveyor since the lot I'm using was only traced from google earth. I just converted the azimuth to lot bearings based on the tutorials on the internet. However, when I plot the bearings I made, they do not match the shape of the lot I traced. What should I do?
Replies (10)
Message 2 of 11
j_gonzaga_528498
Here's the file, btw.
Message 3 of 11
Kent1Cooper
I think you have the syntax of Surveyor's Units with the compass-direction parts reversed, whether that reversal is part of converting azimuth to bearings, or in applying in the drawing.
For example, in the 1-to-2 line, the bearing direction S18D18'W should mean Southward initially and then swung 18°18' to Westward, that is, in a direction like this:
But you have it going Westward initially and then swung 18°18' to Southward, that is, like this:
What is the source of the azimuth directions you are converting, and how are you doing the converting?  Is azimuth direction zero [as I think is typical in navigation and compass-oriented usage] North?  And do angles progress upward from zero in [as I also think is typical] clockwise direction?  If so, you may be able to solve it just by changing your ANGBASE and ANGDIR System Variable settings [read about them in Help].  In AutoCAD, by default, as in mathematics [e.g. geometry], zero° is to the right, and angles progress upward counterclockwise, so you need to change those settings if you want compass azimuth usage.
Kent Cooper, AIA
Message 4 of 11
autoid374ceb4990
What are azimuths on the lines in your drawing?
Attached is a drawing with the bearings and distances as calculated by my software.
Message 5 of 11
j_gonzaga_528498
I'll try this. Thank you!
Message 6 of 11
j_gonzaga_528498
Thank you so much for this!
Message 7 of 11
autoid374ceb4990
These settings have never made much sense to me, but to display surveyors bearings correctly in AutoCAD, use these settings:
I am using an old version of AutoCAD, not sure where you set these in the newer versions.
Message 8 of 11
AllenJessup
You can plot Azimuths directly by setting your 0 direction to North and your angle to clockwise. Azimuths are measured from North in a Clockwise direction. So East would be 90°, South would be a 180° Azimuth, West would be 270° and North 0°.
Allen Jessup
CAD Manager - Designer
Message 9 of 11
autoid374ceb4990
In my area surveyors use bearings (like N 35°-18'-48" E) rather that azimuths.  I understand that azimuths can also be used with a south zero reference, but I have surveyed in 5 different states and have never run into a south reference azimuth.  The "surveyor angles" entry that AutoCAD invented was so clunky that I wrote my own software that allows directions (like N 35°-18'-48" E ) to be entered as "N35.1848E" and azimuths, both north and south reference, can be entered by adding a code letter to the angle.
Message 10 of 11
AllenJessup
Yes. In my area too. However the OP said he had Azimuths so that actually makes it easier to plot.
The South 0° reference for Azimuths was an old USGS convention. I believe it was easier when doing sun shots.
A one place I worked in the way-back. They used Azimuths for stakeout. We would reference a backsight with a known Azimuth then turn to the Azimuth for the stake point. I believe this was because it was easier to output Azimuths in the software they were using at the time..
Allen Jessup
Message 11 of 11
autoid374ceb4990
j_gonzaga_528498:
Just out of curiosity, in what units ( meters, feet, ??) are your distance measurements?
