PLOTTING LINE PROBLEM
WHEN I MAKING PDF THE WILL COMING ONE CROSS LINE BUT THAT LINE NOT SHOWING IN THE MODE AND LAYOT.
WHAT IS THE PROBLEM PLEASE TELL ME.
imadHabash
as i understand from your post that you have a line that didn't appear in model and layout space also when print to pdf , you may need to check your layers status ( ON and OFF ) OR unthaw others. !!!! your issue still need more words to describe ... please try to guide us exactly what is the problem. 🙂
Imad Habash
Alfred.NESWADBA
please follow these steps:
  • start AutoCAD, open this drawing
  • start command _AUDIT and option "YES" to repair the dwg-file ==> 290 errors found
  • start command _REGEN and you get a line shown that is unwanted ==> delete this diagonal line
...PLOT works then for me.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
THANKS
