Plotting layers on some sheets and no plotting layers on other sheets
Is there a way to set up sheets to no plot certain layers but the same layer will plot on other sheets.
example : Sheet 1 layer 1 on no print
                Sheet 2 layer 1 on print
imadHabash
If your sheets exist in layouts you can get what you need by freezing those layers in the view port.click inside the vp then type Layer go to VP Freeze column and start select your unwanted layers. this will not effect your other Layouts even the model layout.
Imad Habash
