Plotting Issue/glitch
Has anyone encountered this issue before? when trying to plot to PDF the line work and text "glitch"
imadHabash
Since we don't know your CAD version and the Printer/Plotter  that you use , i suggest :
  • Try using one of the built-in "AutoCAD PDF" drivers.
  • Install and check if there is any updates that may needed . >> Click <<
  • read this article that may help . >> Click <<
Imad Habash
I'm using Autocad 2018 and i have tried using multiple PDF creators including the built-in CAD one.
i tried using  Adobe PDF, CutePDF Writer, DWG to PDF and Autocad PDF and they all have the same issue, it only seems to be this drawing.
RobDraw
Only one drawing? It's a problem with the file. Post it.
Rob
