plotting error in AutoCAD 2014
 i dont know if theres a problem in my file , first when i opening my file i need to revover that file so i can open it , then when i open it , i started to plot that file into pdf , but i cant plot , theres an error says
Job: - Error(s) Did Not Plot Job ID: 1 Sheet set name: Date and time started: 6/20/2017 9:44:46 AM Date and time completed: 6/20/2017 9:44:50 AM UserID: HYPER-AIRE Profile ID: <<Unnamed Profile>> Total sheets: 1 Sheets plotted: 0 Number of errors: 0 Number of warnings: 0 Sheet: LOWERGROUNDGRAVITAS-30X40 - Error(s) Did Not Plot File: C:\Users\HYPER-AIRE\Desktop\RYAN\GRAVITAS\LOWERGROUNDGRAVITAS.dwg Category name: Page setup: Device name: Plot file path: Paper size
thanks
AUTOCAD 2014
@Anonymous, john.vellek has edited your subject line for clarity: plotting error
kite15
Hi acezaphiro,
Firstly, you have to reset your AutoCAD settings to default.. See..
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Next, Open the file and execute the command AUDIT => Yes ..
See the result...Thanks.
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
It does sound that your file has some corruption. Use Audit, Purge(all), and -Purge>Regapps.
Then, examine your layout and it's associated page setup for errors. If you like, you can attach your file to a post so I can take a closer look.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
