>> when I do the dwg to pdf plot everything seems fine but
>> then I print the pdf and some lines do not print or disappear
Do I understand that correct? ... your PDF is fine, you can see all lines in your PDF viewer, but when you print exactly this PDF to a printer/plotter then you have issues?
If that is correct then why asking in the AutoCAD forum, it has created a correct result.
It seems either to be your PDF viewer sending incorrect data to the output device or the printer/plotter driver.
I would suggest to:
- print the PDF to a different device
- use a different PDF viewer and try printing again.
- if these missing lines have all the same color then it might be the ink or toner of your printer/plotter
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
