Plotting a PDF
Plotting a PDF
ejbrownsd
Plotting a PDF
ejbrownsd
I have a large drawing that I'd like to plot as a pdf. However I do not want my PDF to be limited to a standard paper size so that my whole drawing can fit and be readable including having people being able to zoom in.
beyoungjr
How 'bout setting your "What to plot" to Extents, Center the plot, scale to fit, and select a big paper like E size?  You can also set some quality setting for the DWG to PDF so that when zooming it will be high quality.
Any good?
Blaine Young
Senior Engineering Technician, US Army
ejbrownsd
Kinda. It creates a big white border on the top and bottom.
beyoungjr
Maybe you can post your dwg and I can see what settings work best?
Blaine Young
ejbrownsd
I saved it as 2013 so hopefully it is compatible.
Vinayv4v
Because of your Length of the SLD is more compared to the width that's why you are getting a space on the bottom & top
of your model when plotting.
For example
With higher length and small width.
With almost same ratio.
Editing your drawing can get you better results.
The maximum I got from you drawing was using this settings without editing your drawing.
PDF Attached. Hope it helps.
Cheers,
Vinay Vijayakumaran
