Anuncios
Plotting a Drawing in AutoCad 2016
No aplicable
I am trying to plot a drawing with a scale of 3/4"=1'0" but when I click on plot the drawing is nothing but black image, the image shows both in Model/Paper. I am using a Brother printer model MFC-J480DW for the plotting. What am I doing wrong???.
0 Me gusta
Responder
361 Vistas
4 Respuestas
Respuestas (4)
rkmcswain
Are you printing from model space or a layout? In either case, with no other command active, run the command PREVIEW. What do you get? If you don't get an exact preview of how you want the printed output to look, then your PAGESETUP is not correct. Start by correcting that.
R.K. McSwain     | CADpanacea | on twitter
0 Me gusta
neaton
In the Plot dialog box change the "What to plot:" drop down until you see something in the preview. Below is a snip of what you see if plotting from model space. There are different selections if plotting from paper space.
Nancy
0 Me gusta
john.vellek
Hi @Anonymous,
Is it possible to share your drawing?  If so, please apply  a named page setup to a layout so I have your plot settings.
John Vellek
0 Me gusta
No aplicable
Perhaps the driver you are using for your printer does not support images attached in AutoCAD?
What if you print using DWG To PDF.pc3 instead?
Would the PDF created show the image properly?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
0 Me gusta
