Plotting 3d view
Plotting 3d view
fellipehenrique635
Plotting 3d view
fellipehenrique635
Community Visitor
Community Visitor
Im trying to plott a 3d view, but said a error and plot with conceptual view but with less details
pendean
Community Legend
Community Legend
@fellipehenrique635 Ask your IT person (or IT knowledgeable friend, or repair shop) about fixing that system driver for you, nothing to do with AutoCAD unless you are using a dead PC3 file (which you can bypass)
In the meantime, plot to PDF, then from your PDF viewer you can print to whatever working system printer/plotter that is still working on your PC/Laptop.
paullimapa
If you encounter the same error when plotting 2d views then this problem is not caused by a 3d model.
Paul Li
IT Specialist
@The Office
Valentin_CAD
@fellipehenrique635 ,
Follow the instructions from this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
