Plotter confuguration Editor text is not in English
No aplicable
HI All,
I am using AutoCAD 2016 on windows 10. When entering to Plotter Configuration Editor the text is not displayed in English and I can't use it (attached screenshot)
Tried to reinstall the AutoCAD but still occurs.
It worked in the past and suddenly was changed
Please advice
0 Me gusta
Responder
651 Vistas
13 Respuestas
Respuestas (13)
john.vellek
Hi @Anonymous,
It appears that you do switch OS languages on your computer. ENG (English) is selected in your screen shot.  What other languages do you have implemented?
If you remove the other languages does the problem go away?
John Vellek
0 Me gusta
No aplicable
I an using ENG (United States)
I have also HEBREW
Even when removing the Hebrew language it still occurs
It was OK in the past
0 Me gusta
john.vellek
Hi @Anonymous,
Please go to the Windows control panel>Programs and do a Repair on your AutoCAD 2016. Then perform a Reset Settings to Default. Lastly, check for hotfixes and updates for AutoCAD 2016  from your Autodesk Desktop App or from your account page.
If this behaves then go ahead and re-install the Hebrew.
Please add a post with your results.
It would be interesting to see if this problem arises if you install AutoCAD 2018 on your computer. (Only try this after you have 2016 working properly).
John Vellek
0 Me gusta
No aplicable
Hi John,
didn't work :cara_de_decepción:
I perform reset setting to default - no changes
Product Version: m.49.0.0 AutoCAD 2016
Reinstall Hebrew
0 Me gusta
john.vellek
Hi @Anonymous,
Did you go through each of the steps in order?
  • Windows Control Panel>Programs - Repair
  • Reset Settings to Default
  • Install Hotfix 4
  • Install Service Pack 1
My _vernum is M.107.0.26 - please confirm yours by typing _vernum at the command line.
Does the text look like this for all the printers or just the DWG to PDF one? Are there any other dialog windows that are misbehaving like this?
If you go through the above steps and then enter Options>Display, select the Font button and try selecting a different font.
John Vellek
0 Me gusta
No aplicable
HI John,
Still with no success
Perform the steps by the order.
Step 3-install HOTFIX 4 failed (see attached)
my VERNUM: 107.0.0
The text looks the same for all the printers
see attached for my local printer HP deskjet 4500
did the option->display step.
As you can see in the attached that when clicking Fonts, it has the same text looks
0 Me gusta
john.vellek
HI @Anonymous,
Can you try creating a new user on your computer (administrator) and log on with that account to see if the issue persists? (Just launch AutoCAD and dont configure or add anything to it.)
I am concerned that the hotfix gave you that error message. You are running 64-bit yes?
John Vellek
0 Me gusta
No aplicable
Hi
Created new administrator user but still same problem
yes, I am running windows 64-bit
0 Me gusta
john.vellek
HI @Anonymous,
Can you send me a sample drawing file and a copy of your DWG to PDF  PC3 file? I want to see if it breaks on my computer too.
John Vellek
0 Me gusta
No aplicable
sent you via email the dwg
I checked it for other dwg files and it repaat for all of them
also checked the file on my old laptop same installation (windows 10, AutoCAD 2016, with same language pack) and there is no problem (attached screenshot)
0 Me gusta
john.vellek
Hi @Anonymous,
At this point, I suggest you follow the steps carefully in this article for a Clean Uninstall of AutoCAD. Make sure that you run the FIXIT tool from Microsoft too.
Then, following the steps in this post about Installation Best Practices, please reinstall your AutoCAD and let me know the results.
John Vellek
0 Me gusta
No aplicable
Hi
I already reinstalled the AutoCAD (before asking in the forum)
I am afraid that this is not an AutoCAD issue but more a WINDOWS one.
I will do it again per your articles but i am not optimistic
0 Me gusta
john.vellek
Hi @Anonymous,
I am not convinced that this is an AutoCAD issue either but the clean uninstall should give us both a better idea. I kn ow it sounds tedious to go through this again but I imagine it wont actually be that involved and hope that it will return things to normal for you.
John Vellek
0 Me gusta
