>> using that exact method to create my PDF
Thank you for confirmation.
So your question is not about AutoCAD, it's about Adobe Viewer and Bluebeam Viewer ... which are not handled here. In this case please follow the advice from @pendean and ask in the forum or the support of these 2 products.
What you can do too to get more close to the source of this issue ... open this PDF in other viewers too, like PDFXChange or even in your browsers (most can display the PDF without any plugin. Comparing the output might help to find the product which is different to the others.
We might help you with AutoCAD plotting, e.g. to make sure you are using TTF-fonts (not OTF), using "usual TTF" (not any private fonts which are not allowed to be distributed) so you can assume that the operating system used to open/view the PDF already knows this font ... or inside the PDF-Options in the Plot-dialog verify that fonts are embedded in PDF.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
