Anuncios
Plot to PDF
Plot to PDF
No aplicable
Hi there
I am hoping to find a solution on this issue I am experiencing. I have tried various suggestions in forums but none of those seem to be experiencing exactly the same issue.
I have attached two screenshots, both of the original dwg and how it looks plotted, you can see my problem!
What can I do to have the text and blocks printing accurately? It doesn't make a difference if I export or plot, and I have played around with various PDF options and settings. Some DWG files print better than others too I might add, so I am unsure if it is a default setting in the program or individually per document. My background is more so within Illustrator/InDesign and to my experience this looks like a missing link, but I'm not 100% sure if AutoCAD is set up in this same way.
Grateful for any advice!
0 Me gusta
Responder
Soluciones aceptadas (1)
348 Vistas
2 Respuestas
Respuestas (2)
Vinayv4v
Solución aceptada
Turn of the plot object lineweights and use plot style.
And check if issue is resloved.
Cheers,
Vinay Vijayakumaran
No aplicable
THANK YOU!! In the plot style table I don't have acad.ctb which seems strange BUT just turning off the plot object lineweights fixed my problem. You're a gem!
0 Me gusta
