Plot to DWFX error
Plot to DWFX error
Plot to DWFX error
Has anyone else managed to solve this issue - we are trying to publish to DWFX and one file - error message attached below
The file is 6MB ...when it's plotted we get no error messages inside Autocad
We have tried Autocad 2013 and the latest 2025 version..all return the same error
We also have tried printing with using batch plot in a set of 40 other drawings and all the other files publish fine except this one file.
leothebuilder
Have you tried plotting this problem file to PDF?
Try plotting to your regular plotter.
Experience the same problem as DWFX?
PDF works fine -we need to send a DWFX format file to a APP developer who is using the data to associated objects to shapes for their graphical interface
Daren Coles
EMEA & APAC Drawing Office Manager
Complementary Worker on behalf of GSK
GSK
R & D Ware, Park Road, Mail Stop' 1L07
Ware, Hertfordshire, SG12 0DP
Email Daren.Coles@gsk.com
Mobile +44(0) 7969 338522
Tel: +44(0) 1992 502396
[cid:image003.png@01CF07D6.E94961D0]
________________________________
This e-mail was sent by GlaxoSmithKline Services Unlimited
(registered in England and Wales No. 1047315), which is a
member of the GlaxoSmithKline group of companies. The
registered address of GlaxoSmithKline Services Unlimited
is 980 Great West Road, Brentford, Middlesex TW8 9GS.
rkmcswain
Does it print to DWF okay?
Can you post enough of your source DWG where the error can be replicated, so that someone here can give it a try?
R.K. McSwain     | CADpanacea | on twitter
pendean
Community Legend
Community Legend
Which viewer are you using? DWFx can also be viewed in Windows' XPS viewer.
Turn on the plot/publish log (in Options' PLOT tab) and see if it helps identify the problem.
Shawn_Niles
Autodesk Support
Autodesk Support
If you can, please post the DWG source file. If we can test the DWG, it will be much easier to determine what is happening.
Shawn Niles
