Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Plot to a printer is giving me strange results
janu319
janu319
Can anyone please help me with this issue? In the attached test drawing there is layout with one polyline in the paper space, with “Lineweight” =1.00 in layer properties. When I plot this layout to PDF, I do not see any issue, but when I plot the layout or the PDF at a printer, then I see a solid hatch as shown in the picture "A3 print with solid hatch". This happened when I plot on A3 paper. When I plot on A4, then I don’t have any issue. Also when I un-check the “Plot object lineweights” in plot options then also I don’t see the solid hatch but I don’t see the outline clearly.
Thanks in advance for your time.
Replies (7)
pendean
Community Legend
Community Legend
Your PDF and your DWG file both print just fine to paper in a quick test to the nearest printer and plotter to me
janu319
Do you mean there is something wrong with the printer I used!!
pendean
Community Legend
Community Legend
I suspect so, perhaps a driver setting or something: the printer I test here is a Sharp MX series, the plotter is an HP T930 series.
Either way, there is nothing wrong with your DWG or PDF here.
janu319
Thanks @pendean.
I opened the PDF in "PDF-XChange viewer" insted of "Adobe Reader" and printed at the same printer then I do not see any issue, let me check few other drawings and see the results.
pendean
Community Legend
Community Legend
@janu319 interesting finding: thanks for sharing.
Any modern webbrowser can also be used as a very good PDF viewer too these days.
WeTanks
I also tried my printing, no problem.
Maybe it's a problem with your printer.
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
janu319
Thank you all for your time, our network team also confirmed that the problem is with the printer.
At least we have a work around, if the problem occurs to anyone in the future.
