Plot Styles Missing
Plot Styles Missing
No aplicable
When I try to print the print dialogue indicates that the plot style tables are missing. I have tried using STYLEMANAGER, as recommended by autodesk. This opens my "Documents" folder, although in Options looking at “Plot Style Table Search path”->”Plot Style Table Search Path” it lists the folders on my Z drive.
I have another issue which I believe is related. The list of printers listed in the dialogue is limited to my Windows printers. None of the AutoCAD printers, e.g. DWG to PDF, are listed.
Any ideas?
0 Me gusta
Responder
Soluciones aceptadas (1)
2.185 Vistas
4 Respuestas
Respuestas (4)
kadmonkee
confirm you mapping is assigned correctly, in you OPTIONS / Files/ typically these are mapped to a network drive for consistency
plot style search path has options to verify, PMP files, CTB Files, and Devices
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
0 Me gusta
dbroad
Solución aceptada
Did you change your profile switch to a new profile? Check in options on the profile tab and check the file tab settings also.
You could try doing a repair install of the software if that doesn't work.
Architect, Registered NC, VA, SC, & GA.
No aplicable
Many thanks. When I switched profile to the only other one I had that worked ok. Must be an issue with this profile. Will work around it.
0 Me gusta
No aplicable
0 Me gusta
