Plot Style Problem - Color changing not working
murat.ersan254
murat.ersan254
Hi everybody. As you know, the color of 255 doesn't appear on outputs. That's why I want to change the plot settings. On this website, there's this article "https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC.... I did everything but it didn't work. I recorded what I did and posted it below . Could you help me please?
cadffm
See the difference:
255 vs 255,255,255
the difference is: ,255,255
In your ctb Plotstyletable are 255 plotstyle, one for each ACI color (color 1- 255)
255,255,255 is a truecolor and not an ACI color,
so you don't have a plotstyle for this color in your ctb.
Change the object color in your DWG if 255,255,255 wasn't a good choice
Sebastian
murat.ersan254
Well, isn't there any possibility to change the color of "255,255,255" to any other in the plot style manager?
I know I can filter or quick select all the objects with the color "255,255,255" and change their color but I have many drawing files with this color. That's why I don't want to select and modify those object in every file.
