Plot Publish
Plot Publish
Plot Publish
Hello
When i plot to publish to pdf for some reason its cutting off the right side of my title block on all the drawing that i sent, is there a way of fixing this. Not sure how its determing how much to cut off and why its not seeing the whole drawing. When i print preview thru my regular printer it fine , no issues, its only when i go thru plot publish and convert it to a  pdf is when i get this issue, is there a setting im not seeing to correct this.
Thank You in advance
Check the paper size and margins of the PDF printer. Try the same paper size with full bleed see if helps.
