Hi
Wonder if anyone can help.
We have recently upgraded our print server from 2008 to 2012 and re defined all the printers. We have a Xerox Phaser 4100. Previously the Plot preview would show in colour, now the plot preview only shows black and white even though it prints in colour. I have tried multiple drivers but all seem to have the same issue. Any suggestions? Are there any settings that can be tweaked in CAD as other applications can preview without this issue.
we can work around it by chosing a different printer for the preview but it is a pain to have to keep doing that?
Hi
Thanks so much for your suggestion.
I have double checked the defaults and they are set to colour already so unfortunately that is not the solution in this case.
Thanks again
Chris
Did you also install the new drivers on the local workstations or are they running with the old driver?
- alfred -
Was this issue ever resolved? I found this AKN doc (https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Plot-p...), but . . .
This user is the CAD manager and didn't have this issue before. This is a new system, new install. All plot previews are in gray scale.
Thanks for the response!!!
I cannot find anything about the phaser 4100.
The only things I can find are black cartridges.
The 4110 and 4500 series are all black and white printers.
I don't think this is the case, or is it ?
No, not the case. Everyone in the office plots to the same plotter. No one else is having this issue.
No worries, I'm going to try to uninstall/reinstall the software.
I never posted the printer. I assumed you were using the Phaser 4100 as an example. I'm not sure what there printer is, but I do know they purchased it about a year ago.
So we are missing informations!
We see a thread starting a year ago and you stepped in today. As long as you don't give any new informations about your special situation we are assuming your environment and issue is the same as the thread opener described.
If your case is different then please either create a new thread or give us all informations specific to your case/environment.
- alfred -
I figured that since I'm having the same issue (regardless of the plotter) and the AKN document I posted above provides the solution but it's not working I thought I'd ask if it was ever resolved because if it was resolved then the resolution here may work for me.
It is a plotter/printer issue not an autocad issue.
Therefore we need to know the type of printer you are using and most important of all which drivers you installed.
I guess it is not independent of the plotter/driver. But to verify that you might try to plot to another device (other plotter/printer vendor) or at least PDF and see if you also get only grey-scaled output then.
Otherwise my next step would be to uninstall the driver you are using now, search for an alternative driver working with that printer and your operating system (if we would now know the plotter/printer we would be able to help you searching that) and then start the trial with AutoCAD plotting again.
- alfred -
I've already requested the plotter information.
I'll try the other recommendations and report back.
Hi i have the same exact problem, did you find a solution , please if you can inform me thanks
