plot plan
plot plan
Message 1 of 12
plot plan
Hi i got a plot plan the i want to  redraw in AutoCad, but something looks off with the bearings. I know bearing usually looks like this S30D57'08"E but the bearings on the plan looks like this N19d36'47" there is not direction at the end of it. :unsure:
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Post the DWG file, point to the item in question so we can easily find it.
Message 3 of 12
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
There are a variety of Unit formats that can be used to input data into your drawing:
  • Decimal Degrees
  • Deg/Min/Sec
  • Grads
  • Radians
  • Surveyor's Units
If you can attach a scan or PDF of the plot plan I am happy to take a look and see which of these it might be utilizing.
John Vellek
Message 4 of 12
ok here is a the plot plan
Message 5 of 12
Patchy
It's azimuth, measure clockwise from assumed North (North is zero degree)
Message 6 of 12
How would i type those coordinates into the command line?
Message 7 of 12
Patchy
If the azimuth is more than 180 degrees subtract 180 and label the bearing NE or SW (same thing)
Message 8 of 12
john.vellek
Hi @Anonymous,
 Have you been able to work with the Azimuth in the plot plan?  I found a couple apps to convert to Bearing if you are more comfortable working that way. I like the one I grabbed form my iPhone in the Apple Store and I see some in GooglePlay as well. This might make it faster than doing the conversion manually.
John Vellek
Message 9 of 12
What's the name of the app?
Thanks.
Message 10 of 12
john.vellek
Hi @Anonymous,
There are quite a few but it looks like "Bearing and Azimuths" might be a good start - check either store or search the web as there might also be some online converters available.
John Vellek
Message 11 of 12
How should i go about drawing the 16.178 acre area in autocad?
Message 12 of 12
john.vellek
HI @Anonymous,
I apologize for the late response. I am looking at the JPG that you attached but it is so difficult to read that I am not sure which area you are referring to. Is it possible to attach a cleaner copy of the site and also include the drawing you have started?
Here is my drawing that I started but again, it is hard for me to see the numbers on the jpg so I didn't take this too far.
I have included a snippet that shows the command line input to create the geometry.
John Vellek
