Anuncios
Plot PDF Transparency
No aplicable
I have created some different colored hatches, on different layers. To control the color intensity I give this layers a transparency (value 50).
when I want to crate a PDF, the output don't plot all hatches.
I tried Autocad Publish to PDF, NOT working.
I tried 2 different PDF-Printer (AcroPlot+NuancePDF) is also NOT working.
When I make a plot preview in Autocad, I can already see the missing areas not plotted, so I think think its something related to Autocad.
If transparency is turned off everything is working fine.
dose anybody know a solution to fix this?
0 Me gusta
Responder
1.054 Vistas
7 Respuestas
Respuestas (7)
imadHabash
i suggest to download the latest service pack . >> Click <<
Imad Habash
0 Me gusta
No aplicable
I have the latest version. Emoticono indiferente
0 Me gusta
Alfred.NESWADBA
Please try to plot to "DWG to PDF.pc3" and make sure that this PC3 was not created by a migration from a previous AutoCAD release.
If that does not help please upload your drawing and let us know:
  • which version and service pack of AutoCAD you are using
  • which operating system you are on.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
No DWG to PDF.pc3 gives the same result.
if I go to the print dialog and click on preview the generated/displayed output has the errors.
I can change to all the printers and .pc3 I have the output is always the same.
autocad
windows
0 Me gusta
Juergen_Becker
is it ok when you plot on a piece of paper? I would like to know if it is a general problem or only due to PDF output.
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
0 Me gusta
No aplicable
sadly its the same result Emoticono triste
0 Me gusta
Alfred.NESWADBA
Can you please upload the dwg-file so we can test it on our systems?
- alfred -
Alfred NESWADBA
0 Me gusta
