Plot DWG to PDF
Plot DWG to PDF
F.Camargo
Advisor Advisor
Message 1 of 10
Plot DWG to PDF
F.Camargo
Hi all!
I've created several pdf file from autocad (DWG to PDF.pc3).
I can not plot that file, my adobe reader is crashing!!
I've tryied differents methods to fix it in autocad file.
- purge all
- audit
- plot layout model
- plot model space
Does anyone could help me please?
Thank in advance
Fabricio
Replies (9)
Message 2 of 10
imadHabash
Try to PURGE ( regapps ) from -purge command. Then save your file. any changes?
Imad Habash
Message 3 of 10
F.Camargo
@imadHabash  escreveu:
Yes, I did try it too.
I think could be adobe acrobat reader issue.
Have you try to open the file attach. Is everything normal for you?
Fabricio
Message 4 of 10
imadHabash
Yes, I open it and it's fine.
Imad Habash
Message 5 of 10
imadHabash
just a hint:
right click on your pdf file and select any other program from "open with" option.
Imad Habash
Message 6 of 10
F.Camargo
just a hint:
I ve opened on Google, Firefox and it is normal. But It isn't get a custom paper size just like adobe reader does.
That's the problem of other programs!
My adobe reader is not normal, is taking about 15 - 25 minutes to respond after open that file. It is drive me crazy!
Fabricio
Message 7 of 10
imadHabash
I agree!! You may need to check it out.
Imad Habash
Message 8 of 10
F.Camargo
Thank you!!
I will check this out then.
I am going to close that topic as Accept Solution!
Fabricio
Message 9 of 10
F.Camargo
After a year later I solved the problem....
It's because autocad shx texts problem. Just pdfshx command and set 0.
Done!
Message 10 of 10
joaquim.moral
Hi @F.Camargo,
Thanks for coming back to the Community and sharing your solution—it will help other users with the same question.
Best,
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager - EMEA / LATAM and Media & Entertainment lead
