Plot Date Field Format
pmclean
Message 1 of 13
pmclean
I have a field set in my titleblock for Plot Date. (see the attachments) for the field category I have selected and the format. Occasionally when I plot a drawing I see November 20YY and most of the time I see November 2019 (I want November 2019 all the time). I can't figure out what is going on, or what settings I need to adjust.
I've tried changing the format to MMMM yyyy but that just seems to automatically reset to MMMM yy.
Any help or suggestions would be great. thanks
Replies (12)
Message 2 of 13
cadffm
Please upload a sample DWG you see the wrong value.
Sebastian
Message 3 of 13
cadffm
The only way i see this happens:
You used a WRONG custom built fieldcode (%<\AcVar PlotDate \f "MMMM yyYY">%)
Are you really created these fields by hand via field-dialog?
Sebastian
Message 4 of 13
ChicagoLooper
There are two possible reasons why this is happening (most likely it's #2):
  1. Before your plot you need to update the contents of the field. You can do this by entering REA (regenerate all) on the command line. Performing REA will force the field to update.
  2. The variable 'FIELDEVAL' needs to be changed. To get a good understanding how Fieldeval operates, go to Express Tools Tab=>Tools Panel=>System variables Button, then use the bitcode to get the desired results (see image).
All fields will 'update' if bitcode is set to 31.All fields will 'update' if bitcode is set to 31.
Chicagolooper
Message 5 of 13
pmclean
I've attached an example.
the trick so far has been to try and figure out what is causing the field to display incorrectly, most of the time it shows up the way we want it but occasionally it does the 20YY thing.
Message 6 of 13
pmclean
I've checked the feildeval setting and mine is currently set to 31.
Message 7 of 13
pmclean
Here is one that I'm getting the error on.
Message 8 of 13
cadffm
I checked the fieldcode in your error.dwg and what i guessed in my post#3 is correct,
your fieldcode is %<\AcVar PlotDate \f "MMMM yyYY">% instead of %<\AcVar PlotDate \f "MMMM yyyy">%
I don't know how, when, why - i just can say what the current fieldcode is, not what was the code before or point of change.
And because of my knowledge about standard fieldcodes i think to know you created
this fieldcode by hand or macro/script/program, but not via GUI (not via Field-Dialog), right?
(Except you edited the fdc file for that dialog).
Sorry that i can not help more
Are you using special tools
Sebastian
Message 9 of 13
ChicagoLooper
You have an error in your field expression. You need to change the year from YY to yy because upper case YY is different from lower case yy. You must do this:
 1-Delete 'November 20YY' and make the field blank.1-Delete 'November 20YY' and make the field blank.
After you delete the existing field, manually enter this expression as the value for the tag named GHD_DATE. Note the upper case and lower case letters in the expression. It should look like this:
2-The value for GD_DATE should be like shown above.2-The value for GD_DATE should be like shown above.
When you enter the last character, %, you will see ----. It will change to Month Year when you perform plot. Notice the month is using upper case while the year is using lower case.
Chicagolooper
Message 10 of 13
pmclean
thanks for looking into this for me. The field code is different but everytime I try to change it to MMMM yyyy then exit the field dialog box and immediately go back in to it the fieldcode flips to MMMM yy.  I haven't been able to make the change stick permanently.
I don't even know where the uppercase YY is coming from because I always input it with lower case yy.
Message 11 of 13
pmclean
Hey, thanks for looking at this for me. I've tried manually inputting the fieldcode like you have indicated but each time I do it I get #### instead of ---- and then it doesn't update when I plot.  I'm not sure what is going on, but I appreciate the help.
Message 12 of 13
pmclean
of course I send that message and try it again and its successful. my concern is once I've input the field manually and then go back into the field dialog box it reverts back to MMMM yy. see the attached image that shows the steps I took and the end result when I go back into the field dialog box.
Message 13 of 13
ChicagoLooper
Do NOT go back to the field dialog box. If you do, you will override the MMMM yyyy date format. The field dialog does not contain your desired format, that’s why you have to enter it manually.
Chicagolooper
