Plot Crash
Plot Crash
Plot Crash
Hello
I am working on Autocad 2018.
When plotting my layout to PDF Autocad decides to crash completely.
" closed due to an unexpected error "
My sections plot to PDF perfectly fine but not the layout.
I have tried all the options! Even reset my layers and purged.
Someone, ANY ONE! Please help.
Thank you in advance,
Alfred.NESWADBA
Which PDF-driver are you using?
Which version/update of AutoCAD 2018 are you using (please show us a screenshot from command _ABOUT)
And it might help if you open your file using command _RECOVERALL (instead of the standard open workflow), just to see if there exist errors and need to be repaired.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred.NESWADBA
thank you for your screenshot. Most current update for AutoCAD 2018 is update 1.2, you have not installed any of the updates, I would suggest to start with that.
The question is open, which PDF driver did you use?
- alfred -
Alfred NESWADBA
Thank you for getting back to me so quickly Alfred.
I am attempting to plot a A2 Full bleed DWG to PDF.pc3
I have actually updated to the 2020 version and it still didn't work
Alfred.NESWADBA
That was not my idea, I suggested to update AutoCAD 2018 to AutoCAD 2018.1.2
When you try to use "AutoCAD PDF (General documentation).pc3" ... does that work?
Can you try to run the _RECOVER process, just to make sure it's not a bug in the file itself?
You might also upload the file so we can look into it and try to plot your file/layout on our systems.
- alfred -
Alfred NESWADBA
