I'm having poor performance issues with AutoCAD and Civil 3D 2017.
Polylines display improperly when hardware acceleration is enabled. They are offset and not joined visually. They print fine. No help with Regen.
When acceleration is disabled, this problem is fixed, but navigation becomes choppy. It reminds me of having snap enabled. It's difficult to maneuver the cursor.
I looked on the recommended hardware section of the Autodesk site, but saw nothing regarding a dedicated driver for this card. Note this is the Nvidia Quadro M2000, not the 2000M or M2000m mobile versions.
Can someone help with any performance settings to resolve these issues? Maybe Nvidia Control Panel settings?
Scott
Specs:
Asus Z170-A
i7 6700k 4.0
64GB RAM DDR4-2133
Quadro M2000 PCI-E 4GB
Samsung 950 Pro 512GB SSD
Win 10 Pro 64
Solved by john.vellek. Go to Solution.
Hi @seskinner,
Have you tried both of the latest drivers from Nvidia to see if they improve the issue?
If you have the latest, I suggest that perhaps you contact Nvidia to see if they can offer suggestions for improving the performance. I am not trying to pass the buck but want to make sure that they can address the hardware and driver specifics before we look at other options.
Hi John,
Thanks for the reply.
The older driver (369.26) works much better than the newer one (372.95) with both hardware acceleration on and off. There are still some issues, but it is much more responsive and the line offset issue is resolved as far as I can tell. The line smoothness is not as good as the newer driver with HA enabled, but I guess I can deal with it.
Attached are screenshots before I switched to the older driver.
I appreciate the help.
~Scott
http://www.solidworks.com/sw/support/videocardtesting.html
this page is for the best solidworks drivers for your particular system. The M2000 is listed and it is not the latest driver available from Nvidia. They may work well for AutoCAD as well.
