Please help. When scaling the viewport, the dimensions are incorrect; it scales incorrectly.
leonardo1911ch
Message 1 of 10
leonardo1911ch
When scaling the viewport in the layout to any scale, such as 1000/50xp, the dimensions don't match what they're supposed to; they vary by approximately 1 centimeter. My configuration is correct, but when I check the PDF, the measurements aren't correct. The print configuration is also correct. The problem is in AutoCAD.
Replies (9)
Message 2 of 10
paullimapa
could you share this dwg as well as the pdf that was created so community can take a look?
Paul Li
IT Specialist
@The Office
Message 3 of 10
leonardo1911ch
As you can see, the scaling is generally fine, but if you check the measurements in the PDF or printout, the measurements are not correct or exact.
Message 4 of 10
paullimapa
But the dwg you posted does not have a layout that matches with your pdf.
This is what it shows now and there is no scale to the vport on the layout.
Did you create the pdf using a different dwg?
Paul Li
IT Specialist
@The Office
Message 5 of 10
leonardo1911ch
Sorry, upload an incorrect PDF file. The following is the correct one, and as I said, the viewport does not scale well, so the measurements are not correct in the pdf. and the viewport does have a scale, in the custom scale option of the viewport properties the result of using 1000/50 xp is shown, which is 20
Message 6 of 10
imadHabash
The viewport rectangle size is too big !! You need to reduce the size and use the same unit distances for your model CAD elements ( A4=29.7,21 ).
Try to do it and check if any changes?
Imad Habash
Message 7 of 10
imadHabash
Imad Habash
Message 8 of 10
paullimapa
You again did not give me the exact DWG you used to produce your PDF.
The PDF you posted looks like this:
I can see there's a 7 horizontal dimension on top & there's space between the bottom horizontal line and the vport.
But your DWG you posted looks like this:
Regardless, I opened your PDF using Acrobat & performed the Measuring Tool to confirm that the 7M measurement is still accurate:
For the sake of argument I then opened your DWG & made the following changes:
I adjusted the view inside the Vport so that it looks more like your PDF.
I locked the Vport Display.
I added the horizontal 7M dimension up top.
I also added a 1:50 graphic scale that shows in AutoCAD the drawing shown inside the Vport does match the 7 Meter dimension.
All keeping the Vport Custom Scale at 20 just as you had it.
I then created the PDF by using the same PLOT window you shared in a prior post:
This is how the PDF looks like:
I then again opened the PDF in Acrobat & used the Measurement Tool to confirm that the 7M dimension is still correct:
Attached is the revised DWG & PDF I created.
If you're checking the measurements on the PDF by putting a physical scale on a print out and it's not accurate then your printer calibration is off.
There's nothing wrong with the PDF from AutoCAD.
Paul Li
IT Specialist
@The Office
Message 9 of 10
leonardo1911ch
Thanks then it's probably an error in the printer calibration
Message 10 of 10
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
