- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi, I am trying to convert a model that I have designed using Cinema 4d ( C4D ) to AutoCad but I can´t find the right approach.
I did it using the Subdivision Surface and Subdivision Weight commands of C4D, where you first draw a polygon then you assign different "tensions" or "weights" to the lines, dots, or planes of the object and then you smooth it achieving a rounded or more organic model.
Is there any command or way to achieve something like this in Autocad?
Thanks!!
This is the poligon
In red the heaviest part and blue the lightest
final rounded model
¡Resuelto! Ir a solución.
