Placement of text outside dimension
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When there isn't enough room for the text to be placed inside the dimline, you can choose to place the text next to it. That is exactly what I want, but the problem with our new dimstyle is that it's placed too far away in my opinion. Is there a way to change this?
I tried to change some setting's in the dimsyle editor, but couldn't find anything useful there. I played with the properties a little bit and found out that the 'Arrow size' has something to do with it. But ofcourse that also has impact on the size of the tick. I made my own arrow (just created a block of a diagonal line) so I could narrow the size down without ending up with a small tick, but than I have problems with the ext lines (they dissapear when using an own block?) They're only visible with 'oblique', 'architectural tick' and 'dot small blank'.
Moving the node isn't something I prefer to do, because when moving or stretching the dimension, after adjusting the node, will ruin the dimensions, so I always let them be placed automaticly. In this case it doesn't even help, because moving the node results in a static point without the text getting closer to the dimline. The only way to dreate (almost) what I want is to change the properties to "move text, no leader" and then move the node closer by. As I said, also not useful because you have to align the text manually (also vertical) and the dimline will dissapear.
Any thoughts? Thanks!
