Jason,
I've just recently upgraded to ACAD2015 and found that the express tools version of Tedit.lsp wouldn't work. I dug up your routine from my library and tried to use it but without success. I edited your lisp routine by changing the command line from DDedit to Textedit
(progn (setq i -1) (repeat (sslength ss) (setq ename (ssname ss (setq i (1+ i)))) (setq data (cdr (assoc 0 (entget ename)))) (cond ((wcmatch data "TEXT,ATTDEF,MTEXT,DIMENSION,MULTILEADER") (command "._textedit" ename "") )
This seems to have made the routine operate properly.
Without this change I was getting
<Entity name: FFB10F40> at the command line after the first selection of a piece of text.
I assumed the message was due to the command DDedit and Textedit having been swapped or somesuch by AutoCAD. I thought I'd let you know of my edits and check to see if you think this is the appropriate method for getting it to work in ACAD 2015.
J. Logan
Solved by Jason.Piercey. Go to Solution.
If you do it like this.... @Jason.Piercey
....he'll get a notice.
And yes, DDEDIT was replaced by TEXTEDIT for 2015.
Here is the latest version I have in my library
; Jason Piercey . May 29th, 2003 ; similar command replacement for the Express Tool ; called TEDIT that was left out of AutoCAD 2004. ; edit any of the following in one operation. ; Text, Mtext, Attdef, Attributed Inserts, ; Dimensions, ArcAlignedText, and MultiLeaders ; briefly tested, if any trouble just say so. ; Revised: 06/09/2008 JP ; - added support for multileaders ; - reworked error handler and exiting ; Revised 03/31/2014 ; - DDEDIT is obsolete with AutoCAD 2015 ; - Replaced DDEDIT with TEXTEDIT (defun c:tEdit (/ echo *error* ss i ename data) (setq echo (getvar "cmdecho")) (setvar "cmdecho" 0) (defun *error* (msg) (cond ((and msg (not (member msg '("Function cancelled" "quit / exit abort"))) ) (princ (strcat "\ntEdit error: " msg)) ) (t princ) ) (setvar "cmdecho" echo) ) (if (setq ss (ssget '((-4 . "<or") (0 . "TEXT,MTEXT,ATTDEF,ARCALIGNEDTEXT,DIMENSION,MULTILEADER") (-4 . "<and") (0 . "INSERT") (66 . 1) (-4 . "and>") (-4 . "or>") ) ) ) (progn (setq i -1) (repeat (sslength ss) (setq ename (ssname ss (setq i (1+ i)))) (setq data (cdr (assoc 0 (entget ename)))) (cond ((wcmatch data "TEXT,ATTDEF,MTEXT,DIMENSION,MULTILEADER") (command "._textedit" ename "") ) ((= "ARCALIGNEDTEXT" data) (command "._arctext" ename)) ((= "INSERT" data) (command "._ddatte" ename)) ) (while (> (getvar "cmdactive") 0) (command pause)) ) ) ) (*error* nil) (princ) )
And BTW, RK's suggestion worked for me getting the notification. I don't check in much these days (slow forums and dreadful interface keep my participation to a minimum)
Thanks Jason. Much appreciated.
Any luck with getting tedit.lsp to work in Civil 3D 2018?
Here is what the command line says after selecting the text entities:
"Unknown command "ED". Press F1 for help.
<Entity name: AD2B2D40>"
