PGP problem
jimbir
PGP problem
jimbir
I have no problem when I enter DIMSCALE on the command line.
I've added the following command to my PGP file, saved the file, and ran the REINIT command on the PGP file. When I Enter DMS On the command line, I get the "unknown command" message. Could someone help me with this problem?
Jim Birke
DMS,   *DIMSCALE
0 Me gusta
Responder
Soluciones aceptadas (2)
1.814 Vistas
16 Respuestas
Respuestas (16)
imadHabash
while you editing your pgp file from AutoCAD make sure that you press Apply button and confirm changes , make sure that your aliasedit dialog is closed not minimized .
Imad Habash
0 Me gusta
chriscowgill7373
DIMSCALE is a variable, not a command, so you cannot shortcut it using the pgp file.  You would probably have to have some sort of short lisp routine or something that would prompt the user as though they were entering the data for DIMSCALE, and then feed it to the variable.
(defun c:dms (/ rscale)
(setq rscale (getreal "\nEnter new value for DIMSCALE:"))
(setvar "DIMSCALE" rscale)
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Moshe-A
@chriscowgill7373  hi
DIMSCALE is a system variable and it's also a command like any other commands and can be added to acad.pgp to be invoke by a shortcut - give it a try :cara_sonriente:
@jimbir
instead of directly changing the dimscale better use an appropriate dimstyle.
Moshe
imadHabash
it's work fine from my Aliasedit command .
Imad Habash
0 Me gusta
chriscowgill7373
I've learned something new, so I guess I can go to the office now, since I'm already at home?
If REINIT didnt work, can you confirm that you edited the correct pgp file?
(startapp "notepad" (findfile "acad.pgp"))  should open the pgp file that AutoCAD is using.
It should be in the bottom section of your code.
If you edited the correct one, and it isnt working after REINIT, did you try restarting AutoCAD completely?  That should force a reread.
0 Me gusta
jimbir
Thanks for the quick reply. Can you show me how to add that to the PGP file
0 Me gusta
jimbir
Thanks for the quick reply. When I enter Notepad on the command line it asks me the name of the file I want to open. I type PGP and note pad tells me it can't find the file. The location of the file I am editing is located in
C:\Users\JLB\AppData\Roaming\Autodesk\AutoCAD 2004\R16.0\enu\support
jim
0 Me gusta
Alfred.NESWADBA
Please find >>>this AKN article<<< showing how to edit ACAD.PGP.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
Moshe-A
@jimbir
key-in ALIASEDIT command.
0 Me gusta
chriscowgill7373
Solución aceptada
jim
if you copy this:
including all the () and paste it at your command line, it will open the pgp file that AutoCAD is using.
0 Me gusta
pendean
Community Legend
Community Legend
OR try this LISP and skip trying to remember to run REINIT command after esditing the PGP file
;;Edit PGP file then REINIT
(defun c:editpgp(/ pgpfile);command alias editing
(setq pgpfile (strcat "notepad " (findfile "acad.pgp")))
(setvar "re-init" 16)
(prompt "\nACAD.PGP...reinitialized. ")
(princ)
) ;end
0 Me gusta
jimbir
I don't have the aliasedit In my 2004 version of autocad.
0 Me gusta
chriscowgill7373
I believe ALIASEDIT was added as part of the express tools in AutoCAD 2014.
You saved the file, when you reopen it is it still in the file?  Did you reboot AutoCAD?
0 Me gusta
Moshe-A
@jimbir
aliasedit is not exist cause the express tools is not installed.
go to tools\Customize\edit program parameters (acad.pgp) this a little shorter then manually opening the file in notepad.
Moshe
0 Me gusta
jimbir
Solución aceptada
The PGP file that command opened contained shortcut DSC which works. In an effort to find its location I tried the save as command in notebook. At the top of the next window this was listed.
C:\Program Files (x86)\AutoCAD 2004
And not the one in:
I now know everything, I think...
Thanks for your help
Jim
0 Me gusta
jimbir
Chriscowgill7373 Put me on the right track. By following his instructions in post number 11, I determined that I was editing the PGP file stored in my appdata folder and not the one in C:\Program Files (x86)\AutoCAD 2004 Which was the one auto CAD was using. Problem solved.
0 Me gusta
