perspective drawings hatch pattern stretching?
Message 1 of 13
Is there a way finally? I use ACAD for commercial and residential perspective renderings. stretching a hatch to different lengths and shapes is not an issue. but with the advancement of ACAD are you still not able to stretch a hatch pattern in a perspective such as lines or brick?
Replies (12)
Message 2 of 13
Considering the way hatch patterns are defined in 2D space, probably not.  However a regular hatch pattern in a 3D model will provide exactly what you're looking for.
If you do a lot of rendering you should look into 3D StudioMax
Message 3 of 13
Alfred.NESWADBA
I don't see any problem, draw a box, hatch the sides of the box and change the display mode to perspective ...
Can you please describe what you are missing? I don't need to stretch anything to get the hatch and to make the view perspective?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 13
I think he's drawing in 2D not 3D.
Message 5 of 13
Alfred.NESWADBA
Hi @Anonymous
Well, the headline says "perspective drawings ..." ... if perspective objects are drawn in 2D then I guess that is not a job for a CAD-system, is it?
But let's wait for the answer.
- alfred -
Alfred NESWADBA
Message 6 of 13
I am creating these in 2D not 3D. in this case below main corner (right gable end) 100% scale, end of right/left sides 70% scale.
Message 7 of 13
this is a 2D perspective. which is the issue I believe.
Message 8 of 13
Alfred.NESWADBA
Well, I guess you are using a tool in a way it is not designed for and it is not efficient.
How long do you need to define the perspective points (sorry not to know the correct words in English), then draw a lot of lines to these 2 points and then trim them to the vertical borders? Just imagine how long you will have to work if one of these objects have to be moved?
You do have a 3D system, just use it ...
- alfred -
Alfred NESWADBA
Message 9 of 13
-Alfred- that is normally how I do it. line work is simple but creating brick veneer to display this way is the difficult part. I do everything in 2D and there lies the problem. guess I need to take the time to venture out more to 3D to resolve this issue. Thanks.
Message 10 of 13
Okay, that image is not a true perspective unless your end gables are shaped funny.  The only component that appears to approach a vanishing point is the front walk.
Having had to do these kinds of drawings prior to the advent of CAD, true perspectives in 2D are a royal pain in the nether regions, made only slightly better by CAD.  3D perspectives require more modeling but the results are not just more accurate, but the applications of materials can make the end product considerably more spectacular.
Message 11 of 13
pendean
Community Legend
Community Legend
Your drafting in CAD like you drafted in paper: that's the problem, AutoCAD doesn't work like that very well especially with 2D flat hatching.
Hatches are defined in very narrow parameters in AutoCAD, there is no allowance for "scrunching" on one side like you've drawn.
You'll have to get into 3D modelling: it's probably a lot easier if you use AutoCAD Architecture or REVIT instead of plain AutoCAD as most of the elements will be drawn correctly in elevation as models to start with.
Message 12 of 13
SEANT61
Does it have to be a hatch?  There are several add-in programs available that will convert an ortho view to perspective via projection from one rectangular reference to another.  They tend to work with just standard line/curve geometry, i.e.,  the hatches need to be EXPLODEd.
May your cursor always snap to the location intended.
Message 13 of 13
-rculp-
No that is not a perspective, just a flat shot with gradient fill. but is typical of what I do instead of true perspectives in some cases to give a client a better visual rather than a black line drawing. I agree, perspectives are much more difficult in 2D. must venture out more. but thanks for the input everyone.
