AutoCAD Forum
persian and arabic number Problems
11 REPLIES 11
Message 1 of 12
2436 Views, 11 Replies
hello
please help me.
why numbers of persian and arabic fonts are backward in autocad?
for example when i write 5 it convert to backward and no way to fix it.
I must enter 2000 number per day with persian numbers
I try all ways in text style and any settings but not solved.this problem is in our countries is very frequent and is all users problem and not solved.
11 REPLIES 11
Message 2 of 12
imadHabash
would you please show us your case ? and please attache a CAD file as a sample.
Imad Habash
Message 4 of 12
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Which fonts are you using for Farsi and Arabic? Can you attach a sample file and the fonts so I can try entering text also?  How are your text styles configures?
I assume the problem exists when entering text as well as when printing to PDF or a hardware device.  There are known limitations with such text in AutoCAD and it has been brought to the attention of the Development team.
John Vellek
Message 5 of 12
john.vellek
Hi @Anonymous,
I haven't seen another post on this issue from you. Have you resolved your issue?
Does selecting Backwards in the Style definition help with the font being displayed correctly?
John Vellek
Message 6 of 12
in reply to: imadHabash
Hi
I attached a file
you can see persian numbers front of english numbers.
I must use that type of fonts.for example (font name) : naskhd
every digit is backward in its place.
thank you
Message 7 of 12
in reply to: pendean
thank you for reply.
but my problem is not print
I must use persian numbers more than 2000 time every day
I use a lisp that name is numinc.
it work but i cant use persian number and numbers are backward in its own place.I attached a file
Message 8 of 12
in reply to: john.vellek
Hi john and thank you.sorry I was in vacation
yes.i will send you font
that name is naskhd
we solved print problems
but I cant use fonts in lisps properly.
I send lisp + font
I want enter many numbers with this lisp in persian fonts correctly
thank you
Message 9 of 12
pendean
>>>...I use a lisp that name is numinc...<<<
>>>...I want enter many numbers with this lisp in persian fonts...<<<
You and the lisp author need to be talking to each other.
Message 10 of 12
john.vellek
Hi @Anonymous,
I don't see the lisp file. I suggest however that you post this question (along with the font and LISP) in the customization forum where you will likely receive more suggestions and solutions.
John Vellek
Message 11 of 12
thank you for suggestion.
Message 12 of 12
sorry.I forget to add lisp
do you test that font?
AutoCAD Inside the Factory
