Performance, General
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Having long xref load times, long regen times (at times) and long publish times.
Note I have another thread that was started that kind of got convoluted so I'm abandoning it. Established that my current system is pretty much fine and some drawing clean up I could do to correct any drawing issues. I've taken all that advice with some success but still having uncomfortable issues.
I was asked for this in other thread so here goes.....
My laptop is an ASUS ROG Zephyrus G14GA401 IV
I'd like to get to the bottom of some of this.
1. I ordered more ram. Currently have 16 gig. Replacing one 8 gig stick with a 32 gig stick hopefully early this week.
2. My laptop is capable of handling a total of "approved ram" of 32 gig. For my setup I have one stick of 8 gig on board not accessible ram (soldered) and 1 stick 8gig in a slot that I can replace. Approved total ram is 32gig (8 gig soldered +24 gig stick. But, no such thing as a 24 gig stick so I had 2 options- Replace the 8 gig stick with either 16 or 32 gig stick. The 16gig stick approach is "approved" (Total 24gig) whereas the 32 gig (Total 40gig ram) on board ram will have some "issues", primarily related (and I'm not 100% clear on this) related to only a certain portion of the ram being utilized as dual channel. Otherwise the ram itself is identical. So, this leads to next question.
3. Does autocad take advantage of dual channels? Would it be using dual channels when I publish from within the drawing. Which leads me to my next question.
4. There are HUGE HUGE, I'll repeat HUGE performance differences when I publish from within these particular types of drawings vs when I "publish" through using the sheet set manager. If I shift select multiple tabs and publish it takes forever. If I publish by sheet set manager and select the sheet set folder itself, right click "Publish to PDF" it speeds things up tremendously. I can't for the life of me understand what the difference is. Anyone?
5. I mention 4 because I'm wondering if by not having dual channel ram, it will potentially affect either one of the scenarios..... publishing via sheet set manager vs publishing via layout tabs.
6. Here is a screenshot of my processes.
Memory being used is almost exclusively autocad. This varies and have seen it around 88% at times.... maybe higher
This screenshot is taken when I'm reloading an xref (just one selected for reloading.... not all)
7. I was (and still am) wondering if dropbox might be creating some of these issues. But, as you can see from the processes in the screenshot it doesn't appear to be affecting much. But maybe 170 meg is significant all things considered.
8. When I look at all the processes and my cpu usage never really going above 11% that would say to me that it's a non issue.
9. My GPU similar, never over 10% or so
So, only thing I can figure is that all this is either a ram related situation or a AutoCAD related issue.
Hopefully some of you will have thoughts on this.
