Percentages to Hatch
I have a hexagonal paving pattern, I want to as closely as possible show a random assortment of three different colored pavers. I was wondering if there is a way to hatch a percentage of the total pavers with one hatch.
For instance: say there are 1000 pavers, would it be possible to randomly select 1/3 of the total to then hatch, then of the remaining 667, select 1/2 to assign a different hatch.
Is anything similar to this desired outcome easily possible?
Moshe-A
@Anonymous  hi,
The hatch command has no such options but post a sample dwg so we can see what you mean?!
moshe
imadHabash
i suggest to check if SUPERHATCH (Express Tool) will help you . you can created blocks with different layers, colors, and linetypes to create hatch patterns that react to layer states and plot with a variety of line weights.  >> Click <<
Imad Habash
leeminardi
The following program will randomly change the layer of selected objects to one of three layers.  You may be able to adapt it to your needs.
(defun c:demo (/ r i l n s x)
; changes the layer randomly to one of three options
; layer1, layer2, or layer3
  (setq s (ssget))
  (repeat (setq i (sslength s))
    (setq r (LM:rand))
    (setq x (entget (ssname s (setq i (1- i))))
	  l (assoc 8 x)
    (if	(< r 0.3333)
      (setq n "layer1")
      (progn
	(if (< r 0.66667)
	  (setq n "layer2")
	  (setq n "layer3")
	)				; end if
      )					;end progn
    (entmod (subst (cons 8 n) l x))
  (princ)
;; Rand  -  Lee Mac
;; PRNG implementing a linear congruential generator with
;; parameters derived from the book 'Numerical Recipes'
(defun LM:rand ( / a c m )
    (setq m   4294967296.0
          a   1664525.0
          c   1013904223.0
          $xn (rem (+ c (* a (cond ($xn) ((getvar 'date))))) m)
    (/ $xn m)
lee.minardi
