PDFs crash Canon TM-300 plotter, but not Multifunction printer
Good afternoon all.
When we try to print a PDF file which was converted from AutoCAD in A1 on our Canon TM-300 plotter, the spooler in Windows would always be a total of 6.00MB, spools up to only 2MB and the doesn't print at all. When attempting to cancel the job through Windows, it stays suck at the deleting process. We noticed that when printing from Acrobat, the flattening process stops at 98% for about 45 seconds and then proceeds to do what we described with the spooler. With the behavior is the same using Foxit Reader.
We have tried to print as an image and/or without spooling, but it results with half the drawing being printed and then the plotter stops. The plotter can only print the drawings as a dwg file directly from AutoCAD/DWG Trueview and from this alone we assume that there is a problem with how AutoCAD converts from DWG to PDF.
We also noted that our Multifunction printer can print the PDF files in A3. Can anyone help with this issue? We use a mix of AutoCAD 2021/2022/2023 software.
[ The subject line of this post has been edited for clarity by @pendean Original: PDFs converted from AutoCAD crash the Printer spooler and do not print/ print half the drawing.]
