PDF to Autocad
PDF to Autocad
PDF to Autocad
All of my drawings are in pdf and I wonder which version or versions do it best?
Also how do I convert them?
HELLO@beast23K63X8
You want to convert a PDF file to a DWG file using AutoCAD?
Prior to AutoCAD 2017, it was not possible to convert a PDF file to a DWG file using AutoCAD or AutoCAD LT. PDF files could only be inserted as underlays (external references). The content could then be traced and scaled to known dimensions, if desired.
With the release of AutoCAD 2017, using the PDFIMPORT command, it is now possible to import PDF content directly into AutoCAD drawings. Lines will become editable geometry and text will become editable text. The accuracy of the resultant AutoCAD content is largely dependent upon the quality of the original PDF, so results may vary. Additionally, PDF underlays in drawings created with previous AutoCAD releases can be converted into editable drawing geometry using the PDFIMPORT command.
Using PDFIMPORT with PDFs created from scanned images/documents will result in the creation of a raster image file, which is then attached to the drawing as an xref. The raster imagery will not be converted into editable geometry
IF FIND USEFUL PLEASE ACCEPT AS SOLUTION BY CLICKING ON "Accept Solution"
ABHISHEK BHATIA
pendean
Community Legend
Community Legend
Hi @Anonymous
Good Day ...!
As far as my knowledge there is no authentic tool come across to solve this solution. U can simply try converting ur pdf to dwg online, like pdf to autodwg (but its not worth it). Ur dwg's get exploded and looks clumsy too.
Yes, pdf to dwg can be done in AutoCad 2017 so can I assume I can do this in AutoCad 2018 as well?
Yes,this can work in Autocad 2018 also.
