Hello All:
I am working at resolving an AutoCAD DWG to PDF issue. I have been using this setting for ages. But recently particularly with large files (ie Building Architecture or Files containing 100+ sheets) I have been getting huge latency issues.
I have found a good working solution but I am looking for a "One Shoe Fits All" fix. For instance I can set up a document with the following PDF settings.
Page Setup:
AutoCAD PDF (Smallest File)
PDF Options:
Uncheck all items under Data.
Change Merge control to "Lines Merge"
These setting will fix the latency and scrolling issues.
Then there is the Mobile option of creating a PDF that is viewable on Android and Apple since my team uses both devices we have found issues with Apple not viewing PDF's that same as Android Causing me to have to Create an entirely separate PDF using the AutoCAD (Web & Mobile) PDF. Same setting as above.
Both solutions seem to work but if I have to make 2 PDF's every single time I create a new document I'm not going to be happy AT ALL.
I'm looking for a fix that can be viewed well on MS and Apple PC's, can be used in MS Teams as well as being able to be easily viewable on mobile devices and needs to be printed from those devices in the office or in the field.
Is there a better solution to this?
I am also wondering if i am losing any integrity to the drawings by removing all the data settings?
Would i be able to extract a PDF later if i needed too? What if someone wants to view layers and the data was never enabled?
Any thoughts are appreciated. Thanks!
