PDF Printing
PDF Printing
colinLYYVQ
PDF Printing
colinLYYVQ
This is may first request for help, I'm a complete novice. The first drawing I completed I printed to PDF and the lines are black and some are grey, the filleted corners don't match up and the text for the measurements are grey. When you zoom in very close on the screen these error do go but you have to be really close. Please can anyone help?
Cheers
Colin
ennujozlagam
try to use another pdf printer driver like BULLZIP and see if helps. thanks
Valentin_CAD
@colinLYYVQ ,
Welcome to the Forum.
Consider using "DWG to PDF.pc3" and "monochrome.ctb" from the Plot dialog.
These other options could also help.
From the PDF Options also consider making the "dpi" quality much higher.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
What are you using to view the PDF?  Acrobat Reader?  That has had some issues with viewing AutoCAD-created PDFs, although they are strictly visual - it does not change how they print or how the information is stored in the PDF.  Usually, going into Acrobat options and turning off "Enhance thin lines" will help.
colinLYYVQ
Thank you
