Pdf print text frame problem
Message 1 of 9
Dear Sir,
When i get print pdf for any documents the text here below show up in frame. And it doesn't appears while i doing preview it. For new drawings there is no any problem. Problem only for old drawings.
I make it all commands below but still we have problems.
FRAME : 0
PDFFRAME : 0
WIPEOUTFRAME : 0
IMAGEFRAME : 0
XCLIPFRAME : 0
Accepted solutions (3)
Replies (8)
Message 2 of 9
Just to make sure it isn't a bug in a printer driver, have you tried chosing another PDF-printer?
I also have had some problems with the standard DWG to PDF and i solved it by using the free CUTEPDF driver.
You can download this driver for free www.cutepdf.com
Message 3 of 9
there is not following options on other programs.
- Layer Informations,
- Hyperlinks,
- Bookmarks.
Autocad 2016 new features.
Message 4 of 9
pendean
Community Legend
Community Legend
Your chosen PDF viewer app has that "box smart text" or words to that effect on. Hunt for it and turn that feature off.
There is nothing in AutoCAD 2016 to do it for you.
Message 5 of 9
ok. i found that the problem is coming from foxit reader, not adobe reader, thanks for your assistance.
Message 6 of 9
BG_Ammel
I have found a few of the PDF readers do not like the SHX fonts normally used in AutoCAD.  I tested two versions of ACAD 14 & 17 with all the different printer drivers.  The results were all the same.  If the default font was txt.shx resulted in boxed text in the PDF reader (using PDF-Xchange).  changing the font to Arial removed the boxed text.  This reader did not have a setting for "smart text".
Message 7 of 9
Message 8 of 9
Alfred.NESWADBA
>> Not True
Looking to the date this thread was created ... it was true, because the system variable EPDFSHX was introduced with service pack 1 for AutoCAD 2016 ... later than this thread was created.
Additional info: now it's called PDFSHX
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 9 of 9
chedinhthang_nuce
Just so simple, use the command PDFSHX, and choose "0".
Done !
