A quick yes/no potentially this morning...
When I import a PDF (PDFIMport), everything comes in as the same layer (or maybe a few different ones), but the colours are different. I usually use this feature to strip down a customer drawing to show just what I need and nothing more. Is there a way I can activate the layer features by colour? Namely freeze by colour?
Mark
Solved by pendean. Go to Solution.
Solved by nfiorentinoUXTB2. Go to Solution.
SELECTSIMILAR doesn't work in this case?
Not sure if that's the case, but when I IMPORT and select the option to bring the original layers, I can edit them as a normal layer. not sure why you couldn't select them unless the file is protected.
Sorry
Like this?
Whether I do it like this or select PDF Layers, it only gives me the image with PDF Geometry and PDF Text. But the colour shows everything either as "By Layer" or as an actual colour, even though the layer is the same. What am I doing wrong??
Thanks.
*tips hat* Much obliged Sir.
Is there anything you recommend? I spend a reasonable chunk of time stripping and trimming so it be may be a worthwhile purchase...
