PDF Import Issue
PDF Import Issue
Message 1 of 15
PDF Import Issue
I scanned a small graphics from a catalog and can not get it to import.  It says "No objects were imported" "The specific page or area of the PDF file contains no objects."  It shows the graphics in the preview but when you click OK it says what I stated above.  I even drew a few lines on a peice of paper and it say the same.  When I import a PDF file that was made from a Autocad dwg it works fine.  Any ideas?  Thanks
Replies (14)
Message 2 of 15
dbroad
What filetype did you save the scanned file as?  PDFattach works with saved PDF files only.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 15
I saved them as a PDF file.
Message 4 of 15
TheCADnoob
can you open the scanned PDF in a regular pdf viewer?
CADnoob
Message 5 of 15
Yes.
Message 6 of 15
TheCADnoob
would you be able to provide a PDF for verification?
CADnoob
Message 7 of 15
I attached the file I'm talking about.  It's a pretty rough graphic but thought I would see if I could clean it up once I imported it.  Thanks.
Message 8 of 15
pendean
Community Legend
Community Legend
Scanning creates raster PDF files: basically pictures. AutoCAD does not convert pictures.
AutoCAD creates vector PDF files, those are still objects in and of themselves. PDFIMPORT imports these only.
You wil need to contact YANMAR, the authors of your graphics booklet, for CAD content.
Message 9 of 15
TheCADnoob
As this is a scanned PDF in the area that has PDF data to import make sure you have "Raster Images" selected.
CADnoob
Message 10 of 15
Thanks all for the input.  I knew the import was a raster image but I guess I was hoping it would convert it to lines and arcs so I could modify it.  Thanks again.
Message 11 of 15
TheCADnoob
As of right now no auto convert
You can try vercotrize it or raster CAD or just doing a tracing, but given the content of this image you will probably do better by doing what @pendean mentioned and contact yanmar
Short of that if you have the actual document number i might google search the document number followed by pdf and you might get lucky and find a vector PDF, but if experience has taught me anything its that that would be too easy hehe.
CADnoob
Message 12 of 15
dbroad
I typically use PDFattach to place the image and then scale the object so that the size matches the dimensions. Then I trace over.  It takes relatively little time for simple shapes from a catalog page.
Message 13 of 15
Thank you! I have been at this for an hour.
Message 14 of 15
how can I import pdf
no option on pdf file
Message 15 of 15
Here's another issue I encountered today. When I try to import a PDF file I get an error message that says, "You have selected an unsupported DGN file. Only V7 and V8 DGN files are supported." This only happens on file that a certain vendor has supplied me with. I have successfully imported PDF files from other sources. The error comes up before I get to the dialogue box.
